can't install ms office toolkit 1.1.1 to LV8.6
anyone had had a problem installing the MS office toolkit 1.1.1 to LV ver8.6? I did unistalled 8.5 where the toolkit worked fine. I installed to another directory and seems to install without any problems, but when I run vi's where I used the toolkit they don't work well (I get errors realted to the tool kit subVI's). very strange stuff. thanks for any help.
(3,177 Views)
       This Error due to Installing the Toolkit  1.1.1 in same location without uninstalling the previous version 1.1.1.  If you want to install it once again, uninstall the previous toolkit and install.
       If you ignore this error it will overwrite the toolkits. If the problem still continues,Try with latest toolkit (1.1.2).
With Regards,
Vijay Smiley Happy
(3,160 Views)
Thanks Vijay for responding. I did uninstall the toolkit, and then re-installed to the 8.6 location but the problem persists. Is 1.1.2 a free download, and if yes, where can I download it?
(3,138 Views)
Hi Otman,
You can install an evaluation version of the newest version of the Report Generation Toolkit for Microsoft Office, which is actually now version 1.1.3 here. Download and run the .exe, and then you can activate the product using your activation information.
Stephen S.
Applications Engineering
(3,082 Views)
