generation of wrapper will not finish
I'm trying to create a wrapper dll.
When I get to the generation process it seems to stall.
Has anyone else seen this before
(2,612 Views)
A little bit more information would be helpful, e.g.:
  • What do you mean by "create a wrapper dll"?
  • Are you possibly talking about creating wrapper VIs from a dll using the "import shared library" wizard?
  • What is your LabVIEW version?
  • Where does the dll come from?
  • What do you mean by "seems"? How long did you wait?
(2,610 Views)
Yes I'm creating a wrapper vi.
I'm using the import shared library wizzard.The wizzard stops and stays on the generation process page.
I had to cancel the process to get out of the wizzard.
The dll i'm importing is written in c++.The wizzards is able to see all the funtions of the dll.
I'm using version 8.5
Thanks for the input
(2,583 Views)
You mentioned you have a C++ DLL. I'm assuming you've adorned each function with the extern "C" modifier?
Message Edited by smercurio_fc on 09-22-2008 10:00 AM
(2,546 Views)
