can u add icons to the run time menu
Is it possible to add pictures or icons to the run time menu, so that for example if a menu option is called calculator then I can place a picture of a calculator next to it.
thanks
(3,107 Views)
Hi!
Check out this article on importing picture to the front panel:
http://digital.ni.com/public.nsf/allkb/328AF568F15B36328625696200511EF0?OpenDocument
Product Support Engineer
(3,073 Views)
Thanks, but I don't know if this will allow me to put a pricture up in the run time menu.
What I would like to do this say put a picture next to say the 'Save As' command in the File menu when I run my application.
is that at all possible
(3,068 Views)
Sorry, I misunderstood your question.
The run-time menu can be edited for custom items (http://digital.ni.com/public.nsf/allkb/17803AA31C8C07C986256CFD0080D609?OpenDocument), but there isn't an easy way to add icons to the menu. This isn't an option for the Menu Editor. It isn't a bad idea though. If you'd like, you can go to ni.com/contact, and select "feedback" under Product Feedback. Tell us everything you'd like to be able to do with icons on the run-time menu. R&D views these suggestions regularly and create timelines for incorporating suggestions into future releases of LabVIEW.
(3,036 Views)
sure
thanks anyway
(3,034 Views)
