multithreaded client labview
I am using a vi with which needs to read from two server's into two clients.  The problem I have is that one will not continue without first receiving data from both clients.  I am trying to set them to be separate threads so that this will complete the program as the data comes.  Also I want this to able to handle messags with data only comming in from one end as well as both without haveing to create a separate vi for this case.  I have added my code please take a look and let me know what fixes I could make for this to work.
Thanks in advance for the help.
(3,062 Views)
You need to learn more about how LabVIEW works in terms of dataflow.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours <p>&nbsp;</p>
Your two TCP/IP reads occur together in a flat sequence structure.  Your code can't continue to the next frame until both of those functions have completed execution.  You have other pieces of code such as writing an empty string to numerous terminals and local variables just sitting out in space.  This would lead to a race condition because there is no dependency on when those bits of code execute.  The local variable could be cleared first and the terminal written to later in a loop iteration, or vice versa.
<p>&nbsp;</p>You have a couple other oddities with so many strings that seem to have similar names and some doing the same things and some not.  Such as 3rd Party Device and 3rd party box.  What are the purposes of each of those.  Third party device only ever has an empty string written to it, while 3rd party box is the one you seem to use for putting into an array.  Also, there is no need to write an empty string to the terminal 3rd Party Device and to its local variable at the same time.
<p>&nbsp;</p>If you want the two TCP reads to be truly independent, then you need to put them in separate while loops.  Then look at the structures in the synchronization palette such as rendezvous', semaphores, queues and/or notifiers to control data flow and pass information between the separate loops.  Eliminate as many local variables as you can and use wires to flow the data from one part of your code in a while loop to another.  Your logic for comparing the two strings to each other to determine which came first makes no sense to me.
And having an infinite timeout on you TCP read functions is a bad idea.  If network communication breaks down, your program will freeze forever on those TCP reads.
Also look at the producer/consumer design pattern as a way to use queues to have separate loops communicate with each other such as loop for each TCP read communicating with a loop to write the data to the file.
Message Edited by Ravens Fan on 11-22-2008 12:50 AM
(3,038 Views)
Thanks for the constructive criticism. I'll look through the toturials and try to impove my code as well as better understand the dataflow.  Also really appriciate the help in how to get the two sockets to be completly independent.
(3,002 Views)
