can we have 3 way vertical toggle switch, with unstable position at top, neutral position in center and stable position at bottom. the shape of the switch should be same as that of vertical toggle switch.
(2,618 Views)
Avon,
You've asked the same question and received several replies in two recent threads here and here.
Rather than start a third thread, it would be best to just respond in one of them with details as to your problems with the proposed solutions (e.g. use of picture control).
Fading out. " ... J. Arthur Rank on gong."
(2,602 Views)
