can we use NI examples as Sub VIs?
Hi all,
I am trying to use NI DAQmx Continuous Analog Input read example as a sub VI in my main application. I am not able to use it. Can any one please help me.
Manjunath Kamasani
KM
(3,260 Views)
hi
Yes you can use the example VI in your code . But in order to avoid any change which you make to the example vi to get reflect in the examples itself
save the additional copy of the example VI and then use it as subvi
(3,253 Views)
Continuous example? Then you have to either make sure that the call to it as subvi opens the front panel window. Otherwise, it will block indefinitely or until an error occurs....
Norbert
Norbert
Expert: Geometry
(3,223 Views)
Accepted by KevinKM
As mentioned earlier, make a copy of the example and then edit it to work as you need it.  For instance, I'm pretty sure the examples do not have the connector pane wired up.
(3,213 Views)
Thanks ppl, it worked
KM
(3,171 Views)
Hi
just for your info. Dont mark your own reply as solution. Mark the reply as solution from where you actually got help.
(3,101 Views)
And don't forget to give Kudos to those who helped.  That is like a "thank you" to us.
(3,095 Views)
