can you add how many "trues" have ocurred?
You should really go over your code a bit. Many parts are convoluted, confusing, and overly complicated.
For example an "equal False" is functionally just an "invert". Even better, just wire the control directly to the case structure and swap the cases. Not only is the code much simpler, it is also much less likely to make a logical mistake. Right? 😮
Even better would be a simple "select" (from the comparison palette) instead of the case structure so you can see both strings at once.
Message Edited by altenbach on 12-12-2007 10:45 AM
Message 11 of 12
(439 Views)
Well I definitely came to the right place! All good pointers. I'm a beginner at LabVIEW and have only learned from books and a couple of co-workers, and haven't been to a class yet, though I'm hoping to get to some in town here early next year.
I'll redo this, and thanks for the help! Smiley Happy
Tay
Message 12 of 12
(429 Views)
