cancel message display
    I am using labview 8.6. I am using a display message to user and i am using a D/I through the daq to activate it. the signal will remain at the daq but i want to be able to acknowledge (ie OK ) the message and for it to disappear even when the input is still high.
Backround: labview is controlling a transistor that controls 12V to a pump. when the system is pumping then message is also activated. The message is always active on the screen because the input is always high during the pump operation even when i ok or cancel.
how do i get the message to be acknowledged?
any help would be appreciated.
j
(3,604 Views)
You could use 2 lines, 1 for set the message status, 1 for acknowledge.
You have to ensure you don't send the message twice because you have already acknowledged it but not cleared it. - There is the potential of a race condition here if you are not careful with your logic - i.e. don't send a message when one is already flagged as sent.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,586 Views)
Try this vi.  If pump is off, no message is displayed.  If pump goes on, message is displayed.  Pressing OK button on message pop-up sets the Ack flag.  The message will no longer pop-up.  When pump goes off, Ack gets reset so that the next pump on will cause a message display.
- tbob
Inventor of the WORM Global
(3,569 Views)
thanks bob. thats great help. I will need to play around it to run the pump and the message from the same switch.
j
(3,549 Views)
You can use a two button dialog if you need to act on OK or Cancel buttons.
- tbob
(3,545 Views)
