uninstall application
Hello all,
I created the installer of an application - "MyApp" - (including Labview run-time, DAQmx,etc) and then added the installer to a 3rd party application builder (installaware).
I have a problem uninstalling the application. To uninstall the Labview run-time, DAQmx I use to following command:
%ProgramFiles%\National Instruments\Shared\NIUninstaller\uninst.exe
this prompts the user to uninstall all the Labview framework but does not include "MyApp". During the uninstall it detects that "MyApp" needs some of the software it´s currently uninstalling and prompts the user if he wants to uninstall "MyApp".
What I would like is to have a command that uninstalled silently all LabVIEW software along with "MyApp".
To install I´m using "setup.exe /qb AcceptLicenses yes /r:n" command in order to make the installation without any user interface, so I was wondering if there was something like this for the uninstall.
The product Guid does not seem to be an option because it varies from PC to PC.
thank you for the help,
Adam
Message 1 of 10
(6,828 Views)
The NI uninstaller knows nothing about your app so it would have no way of knowing that it has to uninstall your product. It only installs/uninstalls NI products. You mentioned that you're using some 3rd party installer. Wouldn't it make more sense to direct this question to the publisher of the software that you're using?
Message 2 of 10
(6,821 Views)
I think there is a mixup, "MyApp" is a LabVIEW application that I built using LabVIEW application builder and then launched/called in my 3rd party installer.
In the LabVIEW build options I included LabVIEW run-time, DAQmx, etc to be installed with "MyApp". So I think LabVIEW uninstaller should know how to uninstall "myApp".
thanks,
Adam
Message 3 of 10
(6,813 Views)
As explained in the help, in C:\Program Files\National Instruments\Shared\NIUninstaller, is Uninste.exe and you would invoke it with Uninste.exe /qb/x "name of the software"
Message 4 of 10
(6,802 Views)
I had already seen that command in:
http://forums.ni.com/ni/board/message?board.id=170&message.id=420649&query.id=3830482#M420649
But when I try to run (uninst.exe /qb/x "MyApp") the following prompt appears:
Do you have any idea why?
I also noticed that on your post you state  "Uninste.exe" instead of "Uninst.exe". Is it a typing error?
thanks,
Adam
Message 5 of 10
(6,797 Views)
It was a typo and should be uninst.exe. I also noticed that what I posted was /qb/x but what I actually used was /qb /x (note the space between).
Message 6 of 10
(6,775 Views)
I had already tried it (uninst.exe /qb /x "MyApp") on command prompt. The error is the same "Invalid command line parameters" as in the image of the previous post.
Even if I put "uninst.exe /h" as stated in the error message the error is the same. Am I missing something? Do I need to add something to the installer in LV installer builder?
thanks,
Adam
Message 7 of 10
(6,739 Views)
I saw on: http://zone.ni.com/reference/en-XX/help/371361E-01/lvupgrade/labview_features/
that the command parameters of uninst.exe are upgrade features of LabVIEW 8.6, is this correct? I'm using LV 8.5.1.
If this feature is not available in LV 8.5.1 is there any other way to do this?
Adam
Message 8 of 10
(6,737 Views)
Hi NI guys,
I, also, would sure appreciate an answer to this question. The documentation in http://digital.ni.com/public.nsf/allkb/33434B8E1786A142862574330079237E?OpenDocument indicates that a whole host of uninstall options are available to the user, especially to uninstall NI products themselves. Yet, whenever I use (for example)
' uninst.exe /qb /ForceDependents /x "NI Labview Run-Time Engine 7.1.1" '
at the command line, I get the same cryptic error dialog as Adam. Same dialog appears when I try ' uninst.exe /h '. The above documentation seems to indicate a much richer set of choices should appear in the dialog, and be usable on the command line.
By the way, typing
' uninst.exe /qb /x all '
works just fine to uninstall everything.
To install the NI products, I am using setup.exe from Runtime 3 of NIDAQ 8.7.1, available at  http://joule.ni.com/nidu/cds/view/p/id/975/lang/en.
Tanaya
Message 9 of 10
(6,655 Views)
I figured out that the version of setup.exe and uninst.exe I was using were 2.5.1, which do not support all the current flags.
I am now using the DAQmx 9.1 Core Runtime (installer version 2.7.1) and the options seem to be working fine.
By the way, it's nice that NI is supporting two stripped-down versions of the recent installation packages, but a line-item version would still be much appreciated. I will probably end up using the Configuration runtimeinstead of Core, adding 400MB to my installer just for the useful addition of MAX.
Tanaya
Message 10 of 10
(6,622 Views)
