Showing results forĀ
Search instead forĀ
Did you mean:Ā
cannot download LabView Community Edition
NI's online link to download LabView Community Edition is not working.  I sent a request to Support and they replied with another link, which takes me to an identical looking page.  I have tried downloading the software with the online executable and the offline download ... neither works.  I have tried multiple times over several days ... nothing works.  I have attempted the download on two different computers ... nothing works.   Perhaps someone on this forum knows a valid link to download LabView Community Edition?
Message 1 of 10
(6,238 Views)
I assume the link in question is this one:
https://www.ni.com/en/support/downloads/software-products/download.labview-community.html#521760
Are you logged in to ni.com when you try the download?
Are you trying the regular download, or the offline version?  If you only tried one, can you try the other?
Are you only trying the newest (2024 Q1) version or have you tried some of the older ones too?  2024 just came out a week ago so it could be it has an unknown problem.
Message 2 of 10
(6,185 Views)
The 2024 Q1 is failing for me as well (404 error not found). I get the error for both styles of installer.
The 2023 Q3 seems to work fine though.
Message 3 of 10
(6,160 Views)
Yes, I was logged in when I attempted the downloads.  Yes, I tried the online executable installer and the direct download (for offline installation).  Neither worked.  I tried many times, on two different computers, with antivirus software disabled and with antivirus software enabled (no difference).  No matter what I tried, no file downloaded.
Message 4 of 10
(6,159 Views)
Well at least it doesn't give you the 404 error any more; it just kicks you back to the main DL page.
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(6,127 Views)
Did you try with the older version yet?
Message 6 of 10
(6,115 Views)
I'm not sure what this would accomplish?
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(6,098 Views)
If they just want to get started with LabVIEW community edition I think using an older release like 2023 Q3 for the time being would be fine.
Message 8 of 10
(6,086 Views)
Now when I check the 2024 Q1 Community Edition there is only an offline installer (2.9 GB). When I start the download it starts normally, so maybe you will have success now.
Message 9 of 10
(6,012 Views)
As usual, I am just thinking about one narrow aspect of the problem while you are looking from several different angles.
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(6,006 Views)
