cannot edit enums in 7.1
Since I upgraded from 7.1 to 8.0 to 8.2 I cannot edit typdef enums I created in 7.1 when I try to edit them in 7.1. I can edit them in 8.2, but not in 7.1.Smiley Mad Has anyone else seen this?
PaulG.
Retired
(2,700 Views)
And I can't seem to change control properties, either. Smiley Indifferent
PaulG.
Retired
(2,677 Views)
Paul,
Are you trying to edit typedefs created in 8.2 with 7.1?  I'm a little confused as to what you're trying to accomplish and why you're moving between the versions like that...  If you saved the typdef (or any other VI for that matter) from 8.2, then you won't be able to edit it in 7.1 any more.
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(2,659 Views)
duplicate post, but with better explanation of problem here
(2,654 Views)
