cannot install software on cRIO 9035 LV2014 SP1
I am not able to install software on the cRIO 9035. All it says its for instance
the feature's real-time support for this target type may not be installed
Actually I got RT 14.01.
Cheers,
Steffen
(3,776 Views)
Hi Steffen,
I guess you read the 9035 specs about the software requirements.
- Is the cRIO "clean" (did you deinstall any other software in MAX)?
- Did you try to install the "recommended" software package to your cRIO?
(3,758 Views)
Hi Gerd,
yes, installed all the minimum things
-LV SP1
-NiRIO drivers 15.0
-FPGA 14 SP1
-RT 14 SP1
-formatted the cRIO
-there is no recommended setting in MAX
-I cannot install a single thing, not even just some language support file.
Cheers,
Steffen
PS: I guess best option is to deinstall everything and start again. It was running a cRIO 9074 before on the same PC but that was happy with everything 14.0. So something got messed up while updating.
Cheers,
Steffen
(3,755 Views)
Could you provide a screenshot of the software you have installed in NI MAX? I am concerned that there might be a software version compatibility issue. Also, to clarify, 2014 and 2014SP1 are two completely different versions of LabVIEW.
Alex
Hardware Engineer
(3,732 Views)
I will post a screenshot later, am away at present. I think a clean installation would be the best bet
(3,720 Views)
Accepted by Steffen01
updated to LV2015 SP1, now its working. So I guess there is a driver issue. NiRIO 14.5 and LV14 SP1 just does not do the trick
(3,669 Views)
