cannot open block diagram
If you would like me to look at your files so I can replicate and solve the issue, then please upload them to here in a zip file (like rjwon.zip):
ftp://ftp.ni.com/incoming/
This directory is only open to NI employees so it should be a safe option for your code.
I will be happy to take a look at this.
Message 21 of 33
(3,130 Views)
Hi Mark, ftp site appears as read only for me, is there a password or can you give me an email or contact no to go thru this with you.
Message 22 of 33
(3,104 Views)
Have you tried? It actually is "write-only". You can place files there, but you cannot get them out unless you are NI.
(I just placed this file, no problems)
Message 23 of 33
(3,087 Views)
IE8 on one of my machines has trouble copying to the ftp site. in thtat case I just cut-n-paste the URL into Windows Explorer and then I can copy to the ftp OK.
Ben
Message 24 of 33
(3,075 Views)
Or just  use "Page...open ftp site in Windows Explorer" in IE8. (tools in upper right).
Message 25 of 33
(3,068 Views)
I'm on IE 6.0. I tried some of the things suggested but keep getting the error '
ISA Server: extended error message :
200 Type okay.
500 Illegal PORT command
' Perhaps this may be firewall related.
I'll try sending from my personal pc.
File will be rjwon.zip. let me know if you can view it.
Message 26 of 33
(3,051 Views)
Have you tried passive mode?
Message 27 of 33
(3,034 Views)
I have received the file ok, taking a look now.
Message 28 of 33
(3,024 Views)
I have confirmed my colleagues findings with whom you have been in contact recently. (The VI is beyond recovery). Some comments I have:
- Some of the new VIs you may have used in your updated code could have been saved without a block diagram, causing this error.
- I would recommend using LV 8.5.1, not 8.5. (there are some bug fixes related to this problem).
- You may find this useful reading for other causes of this problem that have not been commented on so far: http://digital.ni.com/public.nsf/allkb/00A6BACDA1C01A0786256B60006163E7
Message 29 of 33
(3,012 Views)
I am trying to open a VI which was not created by me. I am not sure if the VI was saved without the block diagram. All I can access now is the front panel.
I guess this was created in another PC.
Is there any possible way i can get accessto the block diagram of this VI. This is a VI used for commercial Power supply circuit testing .
Thanks.
Message 30 of 33
(2,468 Views)
