case label automatic finish fails with enumerated type (minor bug, fixed in 2010?)
I discoverd a minor bug that may fool a new Labview programmer. When you create a enumarated type and an item has a space at the end, the automatic item completion in a case structure doesn't work properly. As you can't see spaces this van be a tricky thing... Please see attached vi.
I discovered this issue in Labveiew 8.6.1, is it still present in 2010? If so I will create a CAR.
Kind regards,
Mark
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
(3,224 Views)
I can confirm it is present in LV2009 SP1.
On the subject of structure selectors, there are couple of trivial display errors that could be addressed:
21728i81F5CE3351775A90
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,215 Views)
Hi Mark and Thoric,
thank you so much for your post on our discussion forum.
I tried the first post with LV 2010; and I'm not able to reproduce the error over there; Labview keeps the space in the case selector.
I will do a request on the second post to see if the behaviour on the event structure can be improved.
Martijn S
Applications Engineer
NI Netherlands
(3,173 Views)
Hi All,
the refrence for this corractive action request (CAR) is 247094; you will notice this number in the release document when the issue has been fixed,
Martijn S
NI Netherlands
(3,137 Views)
