case selector
Hi guys,
I just wondering at what condition, the second case structure will be true?
I tried couple of times will  different values I gave to elapsed time, looks like no matter what, it always will be false and the true state in the second case sturcture never be executed. May I right?
(4,182 Views)
You need a while loop around the elapsed time VI so that it will continue to check.  Otherwise it only checks one time (immediately after starting the timer).
aputman
(4,164 Views)
The elasped time vi returns a true when a certain amount of time has elapsed...
The input determines how much time this is for or, if left unwired like in your screen shot, it defaults to 1 second.
(4,159 Views)
Thanks for reply
I think I setup my Elapsed Time for 2 seconds in my case, so is that means every 2 seconds I suppose to get a True run once then if I do have a while loop?
(4,148 Views)
I don't understand what you mean here...
(4,139 Views)
Hi, altenbach
I just want to know what I need to do in order to see the True statement been executed in my case?
(4,132 Views)
Accepted by huskerli
You need to spin the loop until the time has elapsed.
(4,129 Views)
