case structure - Labview
I have some data being generated in a "True" section of a case structure and I feed them out of the case to some indicators (and saving in some Excel files). But Labview gives me error that I should connect something for the other case, so I just gave some zero input.
However I need to HOLD the data outside of the case structure until the case structure is "True" again and then update the data.
My code is a little large and I guess I should not give it out, so I cannot upload it.
Baran.
Message 1 of 13
(5,012 Views)
You need your case structure inside a loop with shift registers on the loop which pass data from one iteration to the next.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 2 of 13
(5,006 Views)
You may need a shift register.  Pass the data through the false case.  That will hold the old data.
Lynn
Message 3 of 13
(5,005 Views)
Can you try to make a small vi demonstrating your question/problem?
LabVIEW 2012
Message 4 of 13
(5,001 Views)
Thanks.
I actually did that. But that will keep the data for one more loop and the next one is the zeros that is coming from the other case.
Message 5 of 13
(4,999 Views)
Do what johnsold said...  Don't make it a zero, pass the wire through the false case.
Message 6 of 13
(4,992 Views)
Here is an simple example.
When the Read is pushed,  the indicator should show the control value. But when the read is not pushed I want the indicator keep the last values of control before the Read button is released.
Thanks.
Message 7 of 13
(4,983 Views)
Oh the shift register works now! Thanks.
I guess it was not working well because I was just using one shift register for testing while I had two arrays, and it was mixing the two arrays.
Message 8 of 13
(4,977 Views)
I am a Feedback Node fan myself.
Message 9 of 13
(4,969 Views)
Sometimes it is sufficient to simply place the indicator and save operations also inside the same case structure. No extra code needed. 😄
Message 10 of 13
(4,966 Views)
