case structure - Labview
Yes. Putting the indicator inside is easier. But it was just a simple example. My case was a little different. I needed to get the data from DAQ and calculate things inside the case structure, then stop it so the user can zoom in/out and then outside the case structure save everything in an Excel file using ActiveX outside of the case structure.
The shift register worked anyway. thanks 🙂
Message 11 of 13
(1,229 Views)
I just found out that if I stop the labview and run again, I will lose the data from the shift register. I was wondering if there is anyway, that Labview would keep the shift register values from the last time and update it as soon as I run it again. I have them on the indicators on the screen but when I want to make my excel file then it just gives me empty spots.
Thanks.
Message 12 of 13
(1,191 Views)
Make sure the shift register is not initialized.
If this does not solve the problem, please show us some code. 🙂
Message 13 of 13
(1,188 Views)
