case structure multiple inputs
I do not think you can format the case selector to show leading zeros.  Since only the programmer will see this, he or she will have to adapt to the display of  011 as 11.  You can of course have case 0 as numeric.
Lynn
Message 11 of 22
(8,360 Views)
@captain_harlock wrote:
Although I wonder, isn't there a a much more elegant way of indexing a case struct with mutually exclusive booleans?
This thread is NOT about mutually exclusive booleans, so you should probably have started a new thread. You have a very different problem!
Unfortunately, you don't show the inputs to your "in range & Coerce" functions, so we cannot tell what you are doing and we cannot really help.
Where do the mutually exclusive booleans come from? Is this from an instrument or from a user control?
Message 12 of 22
(8,348 Views)
@paul_a_cardinale wrote:
I suggest using radio buttons.
Unfortunately my booleans are not a manual input (i.e. front panel), they come from a computation about intervals, ranges and max/min outputs.
Message 13 of 22
(8,326 Views)
So why don't you tell us a little bit more? Maybe there is a much simpler solution!
Message 14 of 22
(8,321 Views)
It's not a very big deal.
I'm writing a little program to build the spurious emissions mask limits for a point-to-point RF system.
So on the front panel I have two inputs, the Channel Spacing (CS) value, and the frequency carrier f_0 value, plus a parameter that in the final realease will not be an input but will be taken directly from the Spectrum Analyzer (the Max range of the SA).
There's a fourth param, the breakpoint (BP) frequency, which is the value on which the mask limits jump from -50 to -30 dBm.
So according to the ETSI spec I have 4 cases, mutually excluding:
  1. f_BP is in interval 1<f<(f_0 - 2.5*CS)
  2. f_BP is in interval (f0 + 2.5*CS)<f<(Max SA freq)
  3. f_BP is in interval |f - f_0|<2.5*CS
  4. f_BP is beyonf Max SA freq
Hence my issue with that "boolan driven" case struct.
Message 15 of 22
(8,314 Views)
Build your threshold numbers into an array and use something like what's described here or here. Much less code! 😄
Message 16 of 22
(8,333 Views)
Or here...
Message 17 of 22
(8,331 Views)
Justto put my 2 cents in... regarding to the original subject with multiple Case inputs, I prefer the solution shown in the attached pictures. It uses the type cast function to cast the U32 values to an Enum (which MUST be of U32). This makes it more readible to the programmer.
Enum- Items in Order:
Greets, Dave
Message 18 of 22
(8,310 Views)
everybody, thanks for the hints Smiley Happy
Message 19 of 22
(8,294 Views)
C  B  A     Yellow     Red      Pink     Blue
0  0   1      1
0  1   0                     1
0  1   1                                   1
1  0   0                                             1
Message 20 of 22
(8,156 Views)
