case structure with string as a case selector
Attach your main VI - I'm guessing there may be the issue
Message 11 of 20
(5,082 Views)
i just created the example vi which attached
so that it is simple to understand the problem !
Message 12 of 20
(5,078 Views)
What example?  Nothing is attached.
Message 13 of 20
(5,070 Views)
the one i attached in the beginning !
Message 14 of 20
(5,066 Views)
The very simple one that doesn't match your screenshot in the beginning, the description of your problem, and actually executes just fine?
Message 15 of 20
(5,059 Views)
this is the main code !
i am still working on it
so it will not work and hence vi file  does not hold any importance !
Message 16 of 20
(5,057 Views)
How do you control timing of your loop? I guess the reading and writing is pretty quick, therefore the loop complete quickly so you don't have the chance to see the results. Try running it on highlighted execution, and then observe the LED indicators
Message 17 of 20
(5,049 Views)
The VI file does hold importance because it is the file where your code is not actually working!
Have you looked at the data coming in from the VISA Read and actually compared it to the cases of the case structure?  Did you do what I said and check to see whether any control codes or termination characters are interfering with your case structure comparison?
Message 18 of 20
(5,048 Views)
Accepted by jay_sidd
Oh my...
Right off the top of my head I would do something like this.
=== Engineer Ambiguously ===
Message 19 of 20
(5,032 Views)
u made the day !!
kudos to u !Smiley Wink
Message 20 of 20
(4,993 Views)
