case structure
Attached is a VI I created, I would like to set up a case where I either input -1 or 1 with an control  in the CN . I tried doing it but Im not sure if its correct
Can someone help me ?
(3,435 Views)
Accepted by topic author jcist001
First, You may want to read this There may be better ways to run that device.
I can't get at the command reference from Galil so I don't know what possible values there are for CN But likely you need no case stuctures at all!  (The first one is just a boolean "Not" anyway.)  I don't know what "Polarity" does either but, this "Mod" may be a start in the right direction.
(3,426 Views)
The restrictions for my CN command are either a 1 or -1  those are the only two possible choices. I would like some type of control that would let the user only choose between those two values.
Thank YOU!!
(3,418 Views)
Thank YOU!!
A Boolean would work
(3,413 Views)
Try an enum or radiobutton control. Even a two-line listbox would work.
(3,401 Views)
