restart or reset chassis in Max
I have a 9188 compact Daq chassis with a fixed IP address.  In MAX, what will restart and reset do to it? Will either wipe out my static IP address, etc.?  Thanks.
(3,369 Views)
Accepted by topic author KB_GenMtrs
It will reboot the remote system.  If the IP is static, the IP will remain.  If you have it set to DHCP, then you may get a new IP.
(3,365 Views)
Ok.  I was expecting "reset" to be just like hitting the little black button on the chassis.  -Thx.
(3,351 Views)
