Showing results forĀ
Search instead forĀ
Did you mean:Ā
cdma synchronization
hi all
i'm master student and aim to introduce new spreading code in cdma systems and need to test this sequence in a cdma system to approve the spreading code
all what i need is a simulation for CDMA system in labview to modify it and replace the PN or gold sequence with my new spreading code
can i find an example of that
thnx
(4,400 Views)
Accepted by topic author zainabmaghraby
Hello!
The easiest way to use a CDMA system in LabVIEW would be to use the RFmx WCDMA driver to create the WCDMA waveform. You can then load it into LabVIEW and play it back using the RFSG Playback Library. With this method, you will be able to create and modify your CDMA waveforms and programmatically view them in LabVIEW.
RFmx-WCDMA: http://www.ni.com/download/ni-rfmx-wcdma-2.1/5821/en/
RFSG Playback Library: http://www.ni.com/download/ni-rfsg-playback-library-2.1/5834/en/
RFSG Playback Library VIs: http://zone.ni.com/reference/en-XX/help/375551B-01/TOC3.htm
Paul C
(4,328 Views)
thnx very much for ur help
i would add another question ...which is can i use it with USRP? instead of RFSA and RFSG?
(4,320 Views)
Appreciate this is a little late now, but in case anyone else is wondering!
Short answer, Yes! As long as your using RFSG API that don't actually reference the RFSG hardware, you can use the RFSG VIs with USRP.
In this case the niRFSGPlayback Read Waveform From File just reads a file, and outputs a waveform!
(3,214 Views)
