change 1D array of 32 bit integer to 1D array of BV tag
i just want to change 1D array of 32 bit data type to 1D array of BV tag to display this in Historical trend viewer
an urgent reply wud b highly appreciable
VINO
(2,964 Views)
What you are asking for is not really clear for me... I assume you want your array of numeric values to be replaced by a boolean array.
Also, I was not sure about what numeric value has to correspond with TRUE or FALSE...
Here is a possibility to do this :
I hope this will help you...
Message Edité par TiTou le 03-29-200609:07 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,967 Views)
You will have to write each array value to a unique tag name if you want multiple tags in the historical trend. Wire the I32 array and a tagname array into a for loop with indexing enabled on each tunnel. You will need to convert the I32 into a DBL, the Write tag vi wants a DBL for an analog input. If you don't want it as individual tag values, let us know.
(2,955 Views)
Hello Titou,
why do you use a For loop? Your example will work without!
(2,953 Views)
That's true GerdW,
I always forget and relearn that more and more functions are polymorphic ;)...
nh, this will work the same as the previous I posted :
Message Edité par TiTou le 03-29-200612:24 PM
Epictetus
Antoine Chalons
(2,949 Views)
