change 1D array of data from one row to one column
Hi all,
This may be a really simple questions, but im trying to take two 1D arrays of data, put them in to one array and have that array be 1 column so it looks neat in  a table.
THank you
-Matt
Message 1 of 9
(11,551 Views)
This should be pretty easy to do. Simply run the two arrays into a "Build array" function, then right click the "Build Array" function and make sure there is a Check next to "Concatenate Arrays".
N.B. To put two arrays into a "Build array function" simply place the function and then drag to bottom edge down so that you have 2 wiring points.
Message 2 of 9
(11,537 Views)
MY apolagy, I wrote this backwards haha.  I want the final result to be one row, by however many columns it is.
-Matt
Message 3 of 9
(11,534 Views)
A 1-D array doesn't have any direction.  It can be either a single row, or a single column.  It is all in whatever direction you decide to drag the control or indicator when you show multiple elements.
Message 4 of 9
(11,531 Views)
Accepted by Wolleee
You probably need to transpose the array, since the build array function will append as rows. This will give you colums as you wanted:
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 5 of 9
(11,530 Views)
I re-read your first question. You need to concatenate your two arrays into a 1-D array, then build this (somewhat artificially) into a 2-D array, and then transpose to get your row (the default) into a column. See this snippet:
_____________
Message 6 of 9
(11,515 Views)
None of that is correct.
A 1-D array is just that.  A single dimension.  It can either be horizontal (elements are columns), or vertical (elements are rows).  Whichever way you want to display it.
If you actually want a 2-D array, then say so.
Message 7 of 9
(11,498 Views)
HI RavensFan: It was specified that this data would be displayed in a table, so it must be 2-D. Otherwise, you are right, you can stretch a 1-D array in a horizonal or vertical direction.
_____________
Message 8 of 9
(11,488 Views)
You're right.  I missed the word "table" in the original message.
Message 9 of 9
(11,485 Views)
