change 1D array of data from one row to one column
Hi all,
This may be a really simple questions, but im trying to take two 1D arrays of data, put them in to one array and have that array be 1 column so it looks neat in  a table.
THank you
-Matt
Message 1 of 9
(11,544 Views)
This should be pretty easy to do. Simply run the two arrays into a "Build array" function, then right click the "Build Array" function and make sure there is a Check next to "Concatenate Arrays".
N.B. To put two arrays into a "Build array function" simply place the function and then drag to bottom edge down so that you have 2 wiring points.
Message 2 of 9
(11,530 Views)
MY apolagy, I wrote this backwards haha.  I want the final result to be one row, by however many columns it is.
-Matt
Message 3 of 9
(11,527 Views)
A 1-D array doesn't have any direction.  It can be either a single row, or a single column.  It is all in whatever direction you decide to drag the control or indicator when you show multiple elements.
Message 4 of 9
(11,524 Views)
Accepted by topic author Wolleee
You probably need to transpose the array, since the build array function will append as rows. This will give you colums as you wanted:
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 5 of 9
(11,523 Views)
I re-read your first question. You need to concatenate your two arrays into a 1-D array, then build this (somewhat artificially) into a 2-D array, and then transpose to get your row (the default) into a column. See this snippet:
_____________
Message 6 of 9
(11,508 Views)
None of that is correct.
A 1-D array is just that.  A single dimension.  It can either be horizontal (elements are columns), or vertical (elements are rows).  Whichever way you want to display it.
If you actually want a 2-D array, then say so.
Message 7 of 9
(11,491 Views)
HI RavensFan: It was specified that this data would be displayed in a table, so it must be 2-D. Otherwise, you are right, you can stretch a 1-D array in a horizonal or vertical direction.
_____________
Message 8 of 9
(11,481 Views)
You're right.  I missed the word "table" in the original message.
Message 9 of 9
(11,478 Views)
