change attributes in the opengoop from openG.org
I just installed the opengoop from openG.org, and it seems to be quite easy to use, but I can't find how to change the attributes of the class. If I change the typedef cluster, there are broken wires in the "cal data core" VI. If I unbundle by name the output of the "call by ref" VI, the attributes are the old ones.
Did I miss something or do something wrong?
Thanks future answers
(2,580 Views)
Hi
Just have a look at this discussion in the lava forum http://forums.lavausergroup.org/index.php?showtopic=1306&hl==
I posted a description which should help you handle that problem.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,574 Views)
Thank you very much becktho, everything is ok now.
(2,566 Views)
