Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to change an imported file into an array
Pondered
Member
07-19-2005
09:05 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I wanted to import a file into labview. When I imported it, I used 'read characters from file'. I would like to send each individual data from the file as an array so that I can click on each individually. How can I go by doing that?
0
Kudos
Message
1
of 2
(2,483 Views)
Reply
Re: How to change an imported file into an array
PauloM
Active Participant
07-19-2005
09:15 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There are several methods to manipulate strings and arrays, depending on the data.
If you post your file, it would be easier for us to help you.
Paulo
0
Kudos
Message
2
of 2
(2,478 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
