change blink BG and FG colors
I have four different controls on my front panel. each of them blinks at different stages of the program. I want them to blink in different colors. Which ever is related to emergency, should blink in bright colors, routine ones should blink in softer colors etc. where do I edit/set foreground and background colors for blinking of each control?
Regards.
(3,831 Views)
Hi pcs,
LabVIEW only uses one color for blinking property and that color is set in the LabVIEW options.
To have different colors you could use:
- booleans of different color and switch them (on your own) from FALSE to TRUE and vice-versa
- color box indicators to set individual colors
(3,823 Views)
You can also set the actual FG/BG colors on the controls to simulate blinking, but each class has different properties for these. I once did something like this, but never actually needed it for anything, so I didn't do anything past that test code - http://forums.ni.com/t5/LabVIEW/Frequency-of-Blinking-for-LED-in-LV/m-p/327367#M168545
If you really need this, you can do something based on that, but I would suggest bringing it up to a higher level. Today I might do something like that as an XControl, but that requires understanding XControls.
___________________
Try to take over the world!
(3,814 Views)
i like to do this with system LED's, usually like to overlay them with the blinking led on top layer and transparent in the off condition...
(3,787 Views)
