change file path
I am trying to run the example program  ' learn multiple geometric patterns example vi '' from the ''find examples''.I am not able to run the program with any other images.it is showing error of file path.I tried to change the file path but it is not changing.
Please help me do that.
(3,201 Views)
Can you please post VI
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,085 Views)
I can only see the front panel in the NI website as I don't have vision Module but it looks like that load Path is an indicator not a control.  Right Click the Indicator and find terminal to see what is wired to it.  It will probably be a constant as its and example.  Try changing the constant to a control and browse
to your image from the resulting front panel control.
Hope this helps
Ken
(3,066 Views)
