visa ethernet problems
Hello;
I am having some problems,
 I am using a serial  HHP bar code scanner to get data to lab view,  but I need to use ethernet,   thus  I convert to ethernet using "lantronix uds100 converter"
I configured lantronix converter with IP address and added to Max   and every thing seems to be fine
but the problem is when I trigger the scanner to read a barcode,  because the information never is read by my code
(I proved using serial VISA and works fine   but when I change to ethernet visa does not work and I get an error message
I will appreciate if someone can help me
 thanks
(2,943 Views)
hello
now  I have communication with my serial  barcode scanner and I receive data to my VI through ethernet
but I am still getting " time out expired before operation completed"
any ideas?
(2,891 Views)
If you are able to receive data to your VI but you still getting time out error messages, the reason could be you have specified a Return Byte Count for the read that is larger than the data trying to be sent back. The VISA Read VI is waiting for more data than is going to be sent from Ethernet device. This is why it receives the return data, displays it correctly, and still times out. You can see more information about it at the following link:
http://digital.ni.com/public.nsf/allkb/383FA277AE7A364F862571020074F3EA?OpenDocument
(2,874 Views)
