change graph properties
I need to programically change the color and text on the right Y axis. for example, switch right Y axis text between red "stimulus amplifude" and white "applied voltage". which properties should I use? I managed to find right ones for plot legend, but can't find one for Y axis.
thanks
(2,869 Views)
You have first to set the Active Y scale property to the proper Y scale number, then use the YScale NameLabel Text and TextColor properties.
See the attachment.
Chilly Charly    (aka CC)
(2,864 Views)
I got it. Thanks!!
(2,851 Views)
