selecting Execution Target Option not appear
I have the LabView 7.1 on PC. the Real Time is viewable to me in the "Measurement and Automation Explorer" . I can see the the devices which are present in the Chassis, but when I start the LabView 7.1 for prog. the "Execution Target " Selection Combobox is not Appearing on the window. Can any help how to configure this in my LabView so I can connect the Real Time.
(3,322 Views)
You need to install (re-install?) the Real Time Module.
MAX can see the board by itself, but LabVIEW can only work with it if the RTM is installed.
Steve Bird
Culverson.com
LinkedIn
(3,315 Views)
Thanks for your Reply, But I have one query, I am new to the LabView Environ ment. Can you pls, explain me where to install the Real Time Module. whether on the PC or in the Chassis. & how to install it , whether I have to connect my PC to the Chassis physically with Ethernet Controller. & reinstall the Real Time Module through MAX (Measurement & Automation Explorer ) ?
Thanks & Regards,
Sandeep
(3,314 Views)
The RTM is a software add-on to LabVIEW.
You should have purchased it with your RT board.
It's a separate product, on a separate CD.
Steve Bird
Culverson.com
LinkedIn
(3,309 Views)
Yes We have the Real Time Chassis & the CD Set of Full Dev. System. 1 cd of Full Dev. System & 2 are Device Drivers . I have the updated device drivers on PC other than the drivers come with RT chassis. Can you tell me whether it is compatible with the new drivers ? I have the version of new drivers 7.4. on PC & the chassis have the version 7.1
Thanks & Regards,
Sandeep
(3,310 Views)
It's not a device driver - it won't be on the same CD.
It's a separate product. This link is for the LV 8.0 version - you will have to look around or call your rep for the 7.1 version, or else upgrade your LV 7.1 to 8.0.
Steve Bird
Culverson.com
LinkedIn
(3,304 Views)
