change size of 3d-surface projection
Can I change the size of (zoom in on) a 3D graph inside the graph window?  Spefically, I want to maximize the view of the XY-plane projection in the attached VI.
All I really care about right now is the XY-plane projection.  Is there another way to do this plot without using the projection of 3D surface?
(2,509 Views)
Hi tlawren,
You can zoom in and out by holding shift and clicking in the 3D graph window, then dragging your mouse up or down. You can also pan by using ctrl instead of shift.
(2,481 Views)
