null offset from calibration not being applied to output
I am measuring some load cells using a I 9237.  I am setting the null offset using Device > Bridge Calibration in the DAQ Assistant.  I measure the offet and hit calibrate.  It says "Calibration successful" and I hit finish, but the offset value is not applied to the data.
How do I get this to work?
(2,498 Views)
Hello IamRubber,
How can you see the calibration not being applied?  Are you running the same DAQ Assistant to see the offset?  If possible, please attach a screenshot from before/after running bridge calibration.
Patrick W.
(2,469 Views)
