change tab control page programatically using boolean.
I am wondering if there is a way to programatically change the tabs on tab control when a user clicks a button on  the interface? Here is what I am trying to do and if anybody has any great ideas please let me know. I have a tab control with currently 3 tabs. I want a button on the main area of the vi to go to page 2 and back to page 1 as the user clicks it. The second is that I want about 5 buttons in page 2 that will go to say page 3-5. Any ideas. Thanks
Derek Tucker
Derek Tucker
derek@ponengineering.com
(3,769 Views)
Sure, though I don't know why the user can't just click the tabs themselves. All you need is a simple event structure and writing to a local variable of the tab control.
(3,762 Views)
I know of that, but this is going on a headless operation and the tab control button will be too small. Thanks for help
Derek Tucker
(3,757 Views)
Are you using the tab control in the "Dialog" palette or the one that's built into LabVIEW? If you're using the built-in one then you can change the size of the tabs:
1. Right-click on the tab control and select "Properties".
2. In the "Tab Size" section change the menu to "Fixed Tab Size" and set your height and width as needed.
(3,737 Views)
