change the time loop from 5ms to 250 ms ?
are there any ways you can change the time loop from 5ms to 250 ms ? while test is running ?
example code in labview version 8 are welcome ..  🙂
Message 1 of 8
(3,229 Views)
i want the last loop to be 250 ms..........
Message 2 of 8
(3,227 Views)
Accepted by sticyfinger
Are you referring to a timed loop? You can simply change the dt value using the right-hand parameters.
Message 3 of 8
(3,218 Views)
thank for the fast reply
i want to read something every 5ms.  when stop button pushed i want to wait 250 ms and read again. will this work ??
or should i exit loop then read again ???
Message 4 of 8
(3,205 Views)
That's a little different than what you asked initially. It now sounds like you are trying to do a one-time reading, but simply keep the loop at 5 msec. In that case, just put a delay inside the case structure to cause a 250 msec delay. Use a different button than the Stop button so you don't play games with Boolean functions.
Message 5 of 8
(3,188 Views)
yeah it is. sorry about that.
i want it to stop at it does the 250 ms reading.
Message 6 of 8
(3,183 Views)
i want it to stop after it take the reading after 250 ms.
Message 7 of 8
(3,181 Views)
Then you still don't need to change the loop's time. Just feed out a Boolean constant out of the case structure and OR it with the Stop button.
Message 8 of 8
(3,168 Views)
