change value of button in cluster
Hi all
I just made a simple program to make you understand better what am trying to do.
@Ray
Except the Exit button, there are no common buttons which different panels share among themselves.
every panel has a different set of buttons. so again i have to put all the buttons containing in one panel in a cluster and make it visible whenever that panel is active.
that would lead to same problem again.
Ritesh
Message Edited by ritesh024 on 03-25-2009 08:01 PM
Message 11 of 17
(1,587 Views)
Ritesh,
Put the clusters inside the Stop value change case and see what happens. Looks fine to me after doing that, aside from the fact that you can't use references like that with latch actions.
Message Edited by Broken Arrow on 03-25-2009 09:43 AM
Richard
Message 12 of 17
(1,567 Views)
even if i put the cluster in the "Stop:Value change" , the other 2 buttons(go to page 1 and go to page 2) will still be having the same issue..
Ritesh
Message Edited by ritesh024 on 03-25-2009 08:19 PM
Message 13 of 17
(1,560 Views)
Ah, it's mostly a visual thing that you are fighting. So, you're also fighting the mechanical actions AND the event struncture. You could do This...
Richard
Message 14 of 17
(1,545 Views)
Accepted by LVCoder
There's actually no need to have a cluster since there are actually 4 unique elements anyway.
Have a look at the attached example (LV8.5.1).  There are no clusters and no Local Variable.  Code is also simpler, no Case Structure.
R
Message 15 of 17
(1,528 Views)
Thank You
Message 16 of 17
(1,499 Views)
Glad you liked it.
One key rule to remember with sw.. (or any design)..  Keep it Simple.  🙂
Message 17 of 17
(1,482 Views)
