change xy graph x scale precision
Hello
very simply i need to have fixed  number of digit after decimal point .
I thought i can do it with :
X scale -> Display format precision
but i have faced with this error :
As i scale programmatically scale x-axis (because having more margin) i try this way :
convert float to string with desire precision and then convert it to float .
it works but i thought maybe ther is better way .
Best Regards
Morteza
(4,683 Views)
I strongly recomment the SI format.  Any scale from 0 to any value with 9 digits resolution needed will be hard to read.
Greetings from Germany
Henrik
LV since v3.1
(4,675 Views)
Accepted by topic author mori64
To set number of digits programmatically, you can use "Format string". It does not have 8 digits limit. You can check format strings when you switch to Advanced editing mode.
%#.2g - automatic formatting with 2 digits after decimal point. If you remove #, it will show trailing zeros.
"Increment" is a distance between major ticks. You can also kind of control it using format string by specifying minimum string width
"%-15.2g" - minimum width 15 digits, "-" fill with spaces on right, 2 digits of precision, show trailing zeros.
SI notation is good.
%#_3pV instead of "0.00153" will show 1.53mV.
(4,624 Views)
