changing xy graph axis titles programmatically
I would like to know if there is a way to control the name of the x and y axis labels programmatically on an xy graph. I have a case statement that has 4 different cases, and I would like the label of the y axis to change and correspond with the case that is chosen. I'm using volts, volts squared rms, dBV, and dBFS, and I want the y axis to reflect which case I'm doing by changing it accordingly. The way I want to go about it (if this is possible) is delete the axis title each run and within each case I would program the correct axis label. (Volts for volts, dB for dBFS and so on...)
(11,261 Views)
Accepted by Szklanam
Yes you can use the property node of the XY Graph (YScale.NameLabel.Text and XScale.NameLabel.Text).
(11,250 Views)
You will need to use propery nodes to do this. If you look on the tool palete you you find them here:
Then you will need to find this property
Tim
GHSP
(11,247 Views)
Yes this is exactly what I needed. My case statement only needed to be around the property node. I made 4 different graphs the first time I ran it. But yes thank you much
(11,241 Views)
