characteristic defect
25mV ripple noise on your gate supply is probably the main problem you are seeing.  I like my gate voltage controlled to +-0.1mV.
The other problem might be just the voltage reading accuracy as some of your voltage steps seem to go backwards.
Craig
Message 21 of 27
(1,671 Views)
What about the delay timing before measurements, how should I choise it please, I am really lost.
Message 22 of 27
(1,659 Views)
Hi again community
I am still working on the characteristic of the transistor, I get like  weird plots, instead of the current increases with gate voltage ,it decreases.
the first plot is the white one : Vg=0V.
the second is the red one : Vg=0.1V.
can you help to understand if is it a hardware problem or a software problem.
Message 23 of 27
(1,640 Views)
Looks more like you've fried that transistor and its now behaving like a resistor.  Try another transistor and see if it behave better.  If not and you get the same result, then look at your wiring.  Pay attention to grounding.  If you haven't changed the code its not software related.
Craig
Message 24 of 27
(1,631 Views)
I put the transistor on a shielded box that I made , then I soldered the wires between the pins of the transistor and the NI Elvis breadboard.
I am using the PSU (supply+ to the drain , ground to the source), and one output to the gate.Also one input to measure voltage (input+ to the drain, input- to the source) ,and DMM for current Id.
what if I reverse the measurements by starting with a high voltage on the gate ,then decrease it.
Message 25 of 27
(1,622 Views)
I don't understand what you soldered, but the heat from soldering can easily burn out a device.  Try a new one.
Hi to Lo or Lo to Hi should give you the same characteristics.  So sure try reversing the order to confirm whether the device is dead or alive.
Message 26 of 27
(1,613 Views)
hi
today I tried a new transistor, but  still the resistance increasing  when the gate voltage increase .
white plot:VG=0V.
red plot:VG=0.01V.
green plot:VG=0.02V.
Message 27 of 27
(1,601 Views)
