charge CPU
Bonjour à tous,
Comment connaitre le taux d'ocupation du CPU via labview
Y a t'il un VI? faut'il passer via une commande ?
Cordialement
(4,982 Views)
Google is your friend:
See this thread.
Norbert
EDIT: Or do you use another OS than Windows?
Norbert
Expert: Geometry
(4,976 Views)
Accepted by AFLAMENT
Salut,
en effet Google est l'ami de beaucoup de monde Smiley Very Happy
dans mon cas la solution proposé ne marche pas mais sinon je viens de trouver ça
https://decibel.ni.com/content/docs/DOC-3728 solution qui fonctionne.
C'est fou ce que .NET permets de faire
(4,966 Views)
Well, it does work... at least on my Windows 7....
But of course, the .NET interface is also a beautiful solution.
Norbert
Norbert
Expert: Geometry
(4,943 Views)
OK, in my case i work with XP.
XP didn't have wmic
Thanks Smiley Wink
(4,938 Views)
You do know that Win XP is out of service by Microsoft?
Norbert
Norbert
Expert: Geometry
(4,935 Views)
hi, yes but XP and my old computer do a perfect team
(4,905 Views)
