chart scales
Hi. I'm new to this Labview thingy. I'm having a problem, and this might be a stupid problem. And it is stupid enough to make my head go crazy.
You see, I'm taking voltage input from my NI USB DAQ. In Labview, I connect the DAQ assistant to the waveform chart to view the data.
In Chart Properties>>Scales. I deselect the Autoscale of X-axis and set it 0 to 5.
But no matter what i do, it automatically change the x-axis scales to something like 3.38277E+9 to 3.38277E+9
Any idea?Smiley Sad
(3,733 Views)
Post your VI in LV 8.6
(3,717 Views)
first
you have to specify the card which you are using
AB
Kudos are Accepted
(3,711 Views)
Hmmm... I'm not sure how to change the VI into LV 8.6 Specify the card i'm using? You mean in Labview?
(3,706 Views)
