chart (time value)
hi all
the value on the x-axis of the chart , can it put displayed saperatly . as the chart is basically updating at every point and the time (x-axis) is sorta acts like a counter updating it  value so can i take the value of the  axis value as it is updating ?
regards
Regards
(3,251 Views)
Hi nolsqn,
it's really hard to understand your question...
When I got it right, you want to read the current x axis min/max values. You can do so using property nodes of the chart...
(3,237 Views)
yes i want to read the current x axis min/max values .... but i hav gone through the property node , but  i was unable to extract the information . can you tell me the name of the property
regards
Regards
(3,217 Views)
Accepted by topic author nolsqn
Create ->Property node -> X Scale -> Range -> Maximum, and Minimum.
JD
(you've got to autoscale X plot to make this works, I think)
Message Edité par JDlabview le 06-17-2010 11:45 AM
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
(3,211 Views)
