charting data from text file in LabVIEW 5.1 for Windows
I am having some difficulties trying to figure out how to plot a chart with
data from a file. I would like to be able to read data from a text file
into a chart using LabVIEW 5.1 for Windows. I have looked in the help
within the program and online. I have also looked in the user manual and
the book "LabVIEW for Everyone". Could you please give me specific
instructions on how I would construct the program to be able to do this.
Thank you.
(2,358 Views)
Hi Ellie,
It depends on how data is stored in that txt file. Usually you load the data into an array either using or , the array if necessary and send it to the graph indicator in required form. If you want a more detailed answer, send me a sample data file (labviewer@yahoo.com).
(2,358 Views)
