check a path
I would like to check if the last element of my path is a .dat or a .txt file.
suggest?
thank you
L'asticot
Message 1 of 10
(4,941 Views)
Here is one possibility: convert to a string, then use the attached vi. Similar for .dat.
Paolo
Message 2 of 10
(4,934 Views)
Here's an alternative method:
Message Edited by JoeLabView on 06-01-2007 09:24 AM
Message 3 of 10
(4,929 Views)
In the file I/O-> advanced file functions palette is a VI called get file extension.
Paul
Message 4 of 10
(4,918 Views)
Thanks Paul..
This is a new vi since LV8.x.
I was doing it in LV7.1.
It's good to know the new tricks.. 🙂
Message 5 of 10
(4,909 Views)
Unfortunately JoeLabView's version will find the extension anywhere within the filename, so for instance "c:\path\txtcheck.vi"  will show as a .txt file [The comparison is for an pattern and "." will match ANY character]
This selection should all work; including one that will look for either .dat or .txt in one test. Add error in/out as appropriate.
Message Edited by Rod on 06-01-2007 03:13 PM
Message 6 of 10
(4,909 Views)
Sorry, Joe's test won't match c:\path\txtcheck.vi, but will match c:\path\atxtcheck.vi
Rod.
Message 7 of 10
(4,903 Views)
.....or if you want to do something differently depending on the result, you could get the extension, and use the result as a case selector, either "txt", "dat", or Default.
Rod.
Message Edited by Rod on 06-01-2007 03:37 PM
Message 8 of 10
(4,901 Views)
previous to LabVIEW 8
  1. convert path to string
  2. reverse the string
  3. match pattern [.]+
  4. take the before match output
  5. reverse that string
  6. evaluate the file type
Paul
Message 9 of 10
(4,890 Views)
Very nice Paul!
Message 10 of 10
(4,874 Views)
