check for empty visa resource?
When I am developing the VI at my desk and not a the test station PC, the VISA resource name is empty.
Once the VI is moved to the test station PC, the user can select a VXI board.
How do I make sure the user has selected a VISA resource before continuing?
I can wire a Comparision to check for Empty String, and that works. But is there any method that I should use?
(5,626 Views)
Accepted by nyc_(is_out_of_here)
Try "Not A Number/Path/Refnum"
Or just try to open the Refnum and trap for any errors and loop back to have the user select again.
Omar
(5,623 Views)
Additionally, you can limit the selectable items by interface type. Right-click VISA Resource Name Control and select I/O Name Filtering.
(5,590 Views)
