checking the matching text in the database
Hi jeyanthi,
connect your data to a for loop and check for an empty element. If it is empty, use the "Format into String" function to create your new value.
Mike
Message Edited by MikeS81 on 05-22-2008 08:06 AM
Message 11 of 15
(863 Views)
hi need help ..how to call the same function if i use  one button dialog .
need help plz.thk u
Message 12 of 15
(836 Views)
Hi jeyanthi,
when do you call this dialog? Why do you now speak about a database, i thought your data is from a text file? Can you please explain the relation between your text file and the database?
Mike
Message 13 of 15
(814 Views)
hi Mike ..i have been ask to replace the auto inserting sed num to manual..
example user have to insert a number by himself and aftr he insert i have ti check whethr the number already inserted or not.. tht y i called the function and dont knw how to call the same vi recursively...
Message 14 of 15
(797 Views)
Hi jeyanthi,
here is a simple solution for you. I use the express vi to prompt for input, for a quick example, you can change it with your customized input vi.
Hope it helps.
Mike
Message 15 of 15
(784 Views)
