choice of points from a table ( LabVIEW2012)
 I have written a program in LabVEW2012 as I can choose 2 points or 3 points from a table ... after I solve a polynomial of degree 2 after i have the coefficients . I have written sub VIs that treats each case 2 or 3 to 6 points but I want to give the possibility to the user to enter any  number and there will have a response.
My question is there a way to make a single program that addresses any number that is 2 or 3 or 5 or 7 points?
(2,348 Views)
Using case structure in your program, you should be able to allow user to make choice.
That is pretty straight, I can't understand, what is the bottleneck here...??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,339 Views)
Could you perhaps post a bit of your code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,335 Views)
