clear table with property node
Is there a way to clear the table with a property node? I tried to wire an empty 2D string to the value option of the property node for the table, but that didn't work. Any ideas?
(7,188 Views)
Wiring the Empty array to the Value property node should clear the whole table. Are you updating the value in multiple places? If possible you can attach your code.
(7,182 Views)
Are you sure you have a table?  A table's data is a 2D array (which is what gets displayed).  Writing an empty array to the value property should clear it out.  You could do the same with a local variable.
(7,180 Views)
Actually it does clear it via wiring the empty 2D array to the value setting, but it helps to clear the 2D array feeding the control, Duh!  Thanks guys....
(7,174 Views)
@QRP wrote:
it helps to clear the 2D array feeding the control..
Yes, those default values can be nasty at times...
(7,171 Views)
