clone vi
Can you elaborate for the 2015 software how to change from reentrant back to a normal vi?  I looked under File>VI Properties and didn't see execution under this.  I would like to not have any cloned sub vi's and be able to do my editing as normal.
Thanks!!
-ncm
Message 11 of 14
(2,431 Views)
Thanks!!
You should open it from the project manager.  Opening it from the block diagram opens up that cloned instance.  I assume this is so that when you are debugging you can have any/all of the instances open and can see them all working at the same time.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(2,427 Views)
Just press ctrl+m on the clone and it will open the master for editing
You have to do it on the master. VI properties are greyed out on the clone, so just press ctrl+m first, then change the settings.
Message 13 of 14
(2,420 Views)
Thanks, altenbach!!!!  That is exactly what I needed, much appreciated! Smiley Very Happy
-ncm
Message 14 of 14
(2,393 Views)
